new springs...way 2 high
Old Oct 13, 2005 | 07:18 PM
~87Bird~2.8~'s Avatar
Car: 87 Firebird
Engine: Was 2.8, Now 350
Transmission: V6 T-5
Axle/Gears: 3.45 Open
i am doin a v6-v8 swap in my firebird...and i put new springs it it like im supposed 2...but i put ws6 springs in...and now my car sitts WAY 2 high...even with the engine and tranny in her...italmost all done and look like sh*t sittin up in the air...
i put a sway bar off a ws4 on the front and i have one for the back...my struts r kind of worn...but would any of that matter?...
also off topic, but did ws6 cars have bigger swap bars the ws4's...cuz my parts guy told me 34mm/1 3/8" (i think) was the biggest he could get...kinda found it hard to belive...
any ideas whats goin on would be great..thx
p.s. the springs r for my year ws6
Old Oct 13, 2005 | 10:46 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
are the springs in the pockets correctly? if they arent seated it will sit high... also it takes a bit to settle mine was way up in the air but it came down about 3/4 of an inch but its still too high with the ls1... i hate front springs :|
btw i have 36mm stock sway bar in the front 92 GTA.. most ws6's were 36s i beleive
Old Oct 14, 2005 | 05:13 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Also, new, stock ride height springs will tend to make the car sit higher because your 18 year old springs have compressed/ sagged over the years
Diff.
Old Oct 15, 2005 | 11:08 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The springs on my car are original and they sit 2 inches lower than stock. So if i got a set of two inch lowering springs, the car would sit exactly where it is now.
Old Oct 15, 2005 | 05:09 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I can almost guarantee that the springs just aren't sitting in the pockets. i had the same problem with mine a few times.
Old Oct 15, 2005 | 05:23 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Have you rolled the car back and forth a few feet since you put the engine and trans in, or has it not moved yet? Because of the A-arm suspension in the front, when you jack the front of these cars up and let them down, the car likes to rest on the outside shoulders of the tire, making the wheel gap look a lot higher than it should be. Fix this by rolling the car forward and back a few feet.
If this has already been done...check to make sure the springs are indexed correctly. If that all checks out, then like people have said, replacement stock springs do make these cars look really high.
Old Oct 15, 2005 | 05:24 PM
Car: 1997 Corvette
As for the swaybars, the WS6 cars got 36mm bars. Only a few places make the 36mm swaybar bushings for these cars. They are the 34mm ones that a few companies bore out to 36mm. Spohn is one company and TDS is another, though TDS uses a different brand poly bushing I believe....Guldstrand?
I'm just running 34mm greasable bushings on my 36mm bar. I figure it makes it a bit stiffer.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
