Drag radial tire pressure...recomendations?
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Friday night TNT night I am running BFG 275/50/15 DRs. Does anyone have any pressure suggestions? I am running 14.41 @ 96.63 mph on 235/60/15 T/As.By the way Lost to a 2005
Mustang GT he ran a 14.22 @ 96.60 he holeshotted me really bad, a .082 to my sleepy .318 R/T.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
It's not going to take much to stick with those times, would personally start at 18 psi and not go over 20psi, do a good burnout and race away.
Heh, with those times you don’t even have to go that far… even 26psi or so with an OK burnout will dead hook off the line with that combination (from experience, I’ve tried it on a simlar, slightly faster car with both 275/50/15 and 275/60/15 BFG DR’s)
Car: 1984 Z28
Engine: L69 305 HO
I think in my case its the driver not the car. Ihave to be the absolute worst drag driver in the history of man. No consistency, poor reaction times, you name it, I can muck it up. Last night I ran 3 runs. First run stock dual snorkel air cleaner,no D/Rs, and thru full exhaust 15.38 with .271 R/T, 95.07. I am testing stock L69 cleaner vs. 3" open cleaner. No good results yet on which is better. Second Run same conditions except 3" open cleaner,14.68@96.21 mph .168 R/T. Third run 15.10@95.89 .065 R/T with open dump,D/Rs,open air cleaner and huge stumble off the line. I need to learn to drive. Could not make more runs due to COBA and huge turnout. Its hard to get better when you only get 3 runs a month.
