245-50 and 255-50-16 good combo? and what are some good tires these days.
Old Oct 29, 2005 | 09:20 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I don't drive the car much anymore after I redid and have been away from teh boards for a while, I was just wondering about the tire size combo and what are some good tire out there these days? if you could thel me about there wear and perf. Thanks
I currently have BF goodrich Vr4 tires had the Zr before that.
Old Oct 30, 2005 | 05:20 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am running Kumho Ecsta 711s. 245 50 16. they are cheap and hook pretty well too.
Old Oct 30, 2005 | 05:22 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I wouldn't bother with the extra cm (245 vs 255) because it really doesn't amount to much. A little over 1/3 an inch.
As for tire, I love my Kumho Ecsta Supras (712). They're also pretty well liked on the board and fairly cheap. See above post
https://www.thirdgen.org/techbb2/sho...ht=kumho+supra
Old Oct 31, 2005 | 07:52 PM
BLACK Z's Avatar
Car: 86 Z28
What price are they, what other tires are good? are teh eagle F1 any good? price and wear? thanks
Old Oct 31, 2005 | 11:31 PM
Gummie's Avatar
Car: 88 GTA
Hit up tirerack.com or some similar site and check for yourself. The threads I linked to had prices for the Kumhos.
Old Nov 1, 2005 | 10:46 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I sprung for the 255s on the back and regret it. They are noticably taller than the 245s which is not good for my already crappy rear gear ratio, and, assuming your front and rear wheels have different offsets, like my iroc wheels, you've got to break the tires off the rims to rotate them (Kuhmos and many others are directional). Of course you can't rotate front to back as well.
The Kuhmo Supras are great for the money. Wear pretty good, and bite good once they warm up. Not like a drag radial, though. I had one get a knot on the sidewall and had to replace it, but I'll probably buy another set when my current set goes.
Old Nov 4, 2005 | 08:09 PM
BLACK Z's Avatar
Car: 86 Z28
My Bf goodrich don't seem to have that much of a diffrent look size wise, is the 255 taller or wider then the 245? what would have teh same height but be wider then teh 245? thanks
Old Nov 4, 2005 | 08:45 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
the 255 would be both taller and wider with the same aspect ratio, although not by much.
Old Nov 4, 2005 | 09:36 PM
Engine: tpi 305
Go to tirerack.com and look up the kuhmos. You can click a button that'll let you look at all the tire sizes with the specifications of each. That'll answer your question.
Old Nov 5, 2005 | 01:12 AM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Kuhmos are good for the $$$. It depends what you do with your car. for the street / mild performance the kuhmos are good. For hi-perf street handling get a better tire. I have Bridgestone RE750's on my other car and they offer alot for the value, yes they cost about 50% more than the kuhmo but aren't like twice as much like the F1's , which are no better than the 750's
as I said it depends what you are using them for and how much you want to spend. I am one who believes you shouldn't buy the most expensive tires, but when you buy cheap tires you often get what you pay for. and if you have a fast car, really your life depends on how safe you make the car, and some of the cheap$ tires are dangerous at high speeds, they don't balance well, and don't have the integrity of some of the other tires available, there are honest tire guys who will tell you alot of tires out there are crap.
$.02
Old Nov 5, 2005 | 01:23 AM
Kennerz's Avatar
Oh yeah, I have 255-50-16 Kuhmos on my Iroc, they are good for the price. The 255 ride alitte better than the 245-45-16 that were on the car stock, offer some more contact with the road,and yes it does throw off the speedo some maybe 2-3 mph at 80.
Will be replacing them with new wheels in the comming months , probably 255-40-17 FR and 275-40-17 RR or if it fits ok 275's all arround, I hear it works, but looks awful close on the front , I don't rub with the 255-16's but there is not much extra room in the wheel well.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
gta90
Sep 15, 2015 04:00 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
