shocks in rear causing crappy handling???
Old Nov 3, 2005 | 08:51 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
first of all on my 91 r/s 3.1 camaro do i have shock or struts in the back.,they appear to be just shocks.,.,???
Any way when i go over a speed bump slow the rear just drops like the shocks are warn out,.,.So assuming they are! when i install new ones will it make the rear any higher then it sits now??
Secondly and most importantly! ive noticed crappy handeling while im driveing.,like the rear wants to drift side to side or is just slopy,.will replacing the rear shock's/struts fix this problem im having?????
Thanks in advace to all who help!
Old Nov 4, 2005 | 05:22 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
It's the springs which dictate the ride height, however the shocks may contribute a very tiny amount by wanting to uncompress (don't know if you've noticed that some new shocks come with a strap on them in the packaging - remove the strap and the shock slowly uncompresses).
Should be shocks on the rear, and yes, if the shocks are worn out you'll have very little/no damping on the rear and hence poor handling. At least replacing the shocks will eliminate a possible cause of the handling problem.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
