front sway bar
Old Nov 5, 2005 | 10:08 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
front sway bar
I have a 89 Iroc, would it be possible to have a 36mm sway bar?
I just mic'd it and it was 1.400 and on the conversion chart that is 36mm
Old Nov 5, 2005 | 04:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
JamesC
Old Nov 6, 2005 | 01:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Anythings possible.
Old Nov 6, 2005 | 03:24 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
my 89 came with one stock as well. mine does have the better suspension option, and it had the pbr rear disks. i have seen 89 irocs that had the same suspension trim as mine but didnt have the larger sway bar, and they had drum rears, not disks. does yours have a disk brake rear or drum? the combination of options is probably what determined what bar it got.
thanks
Old Nov 7, 2005 | 06:54 AM
gscz28's Avatar
Car: 89 iroc
drums on the back, seems these bushings need to ordered,
none of the parts stores have anything largere than 1 1/4.
Had an argument with a guy he was saying they were the same,
36mm and 1 1/4, had to go get a mic and show him how to read it.
Old Nov 7, 2005 | 07:08 AM
JamesC's Avatar
The stock 36mm GM bushing, which has a higher durometer than normal ones, is p/n 14094389. IIRC, both Spohn and TDS carry greaseable polly.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
