Still gonna rub with Pro-Kits??
Old Nov 18, 2005 | 02:44 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I just got a set of the Eibach Pro-Kits and the rears are progressive rates (duh). I was wondering if someone could explain how that works.
I have a 4th Gen rear under my car now and it is wider than the factory. So, it rubs the tires on the underside rim of the wheel well. I wanted to make sure that it won't do that with the Pro-Kit. The right side on the factory springs sets at 27.25", the left at 28". Shouldn't the stiffer Eibachs keep the rear from dropping so much?
Old Nov 29, 2005 | 03:16 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Progressive is when the spring compresses more, it becomes stiffer. Its soft at normal ride hight to give a smoother ride.
Old Nov 29, 2005 | 09:39 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
What you mean by underside rim of the wheel well is the "lip" that people roll using a baseball bat? or am I wrong, cause I don't know the official term for that either. Switching springs will probably not cure the rubbing, maybe rolling the fender well "lip" , "rim", "whatever" or banging the spring "pocket" with a big hammer? I've done both since running a variety of different wheel/tire combos' over time. Currently running a 4thgen rear, pro kit, and C5 wheels, this combo rubbed on the spring pocket area until I cut it out. I had already rolled the fender "lip" so I can't say if that would have been a problem area.
Old Nov 29, 2005 | 09:44 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I'll roll the lip after I get it back. It only rubbed sometimes, when I have it pretty loaded with full tank of gas. I hope the stiffer springs keeps it from rubbing. If not, then I'll do more. The car sets only about a 1/4 of an inch higher with the stock springs than it will with the Pro-Kits, so with the much stiffer springs, I should be in the clear with the factory wheels... I hope.
Old Dec 1, 2005 | 01:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I got the springs in. They don't have as much bounce as the stockers. They are a little harsher on serious bumps, but the road ride is better/smoother. Overall, I like them. They lowered the car, but only slightly. About 1/4 inch rear, 3/8 give or take in the front. Haven't had it loaded yet, so I don't know about the rubs...
Old Dec 1, 2005 | 04:45 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
If you are only rubbing sometimes you might get rid of the problem by using a rod ended PHB
Old Dec 1, 2005 | 09:10 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have the combo end (poly bushing/ rod end) PHB. That was my first suspension mod. I need to adjust it now. My rear is a little of center. Plan on getting the LCAs and SFCs next.
MrPackstin
Oct 25, 2017 08:09 PM
92projectcamaro
Dec 8, 2015 12:25 AM
jbates346
Oct 21, 2015 01:50 PM
91 SrS
Oct 7, 2015 04:32 PM
Vincent135
Sep 28, 2015 10:50 PM
