What should be my next suspension mod
Old Nov 25, 2005 | 11:03 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
What should be my next suspension mod on my 1984 z28?
I already have sub frame connectors an I just bought a iroc wonder bar.
I’m looking for inexpensive parts for autocross, street, and strip use.
Also what color should I paint the iroc wonder bar?
Old Nov 25, 2005 | 11:19 AM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
If you do not already have a 36mm front sway bar then that would be the next part to buy. Next up would be shocks but good ones are not all that cheap. I like my Koni sports.
Old Nov 25, 2005 | 02:01 PM
z28z34man's Avatar
I heard that iroc springs would be a good pick up if you don't want to lower your car. Is this true
Old Nov 25, 2005 | 03:43 PM
JTZ28's Avatar
how about panhard rod,trailing arms,tubular a arms or a torque arm? or if you have a pile of money fall in your lap a new k-member.
why dont you want to lower it? i have a 84 z28 with lower springs and it handles great!
what's a wonder bar? could someone tell me/or a picture?
Old Nov 25, 2005 | 04:35 PM
z28z34man's Avatar
maquoketa and lowerd cars don't mix
https://www.thirdgen.org/techbb2/sho...ght=wonder+bar
wonder bar pick in lynk
Old Nov 25, 2005 | 04:47 PM
JTZ28's Avatar
thats what i thought living in montezuma ia bu i havent had any problems except every body in their 4x4's trucks wanting to race me
Old Nov 25, 2005 | 05:52 PM
Souseless's Avatar
Car: 89 WS6
You can install performance springs without lowering the car. If you use ground control weight jacks you can pick your spring length and rate. For a given spring you have about 3" of height adjustment available. My car had WS6 springs in it and they were ok. Now I have the weight jackers with 775 front and 175 rear and 36/24 sway bars and I generally like it better. I think that a smaller rear bar may be in order for me.
Old Nov 25, 2005 | 06:59 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Tubular front arms and kmember are a waste of $$ for what you want to do.
Next mod should be a set of Konis or Billsteins and a good set of springs. I don't think you'll have a problem with a Pro Kit. A nice set of LCA's and an adjustable panhard bar next, and when money allows, a tunnel mount torque arm.
BTW, paint the wonder bar black
Old Nov 30, 2005 | 10:24 AM
z28z34man's Avatar
Any more opinions
Old Nov 30, 2005 | 11:25 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I'm with Dialed-in. Get and good set of shocks/struts. They make more of a difference than anything. Springs are nice, either Z28 if you don't want to go lower or the pro-kit if ya do. After you've done that, drive around and check if the car oversteers or understeers to your liking and adjust the sway-bars accordingly, you'll need to measure the ones you have and then post what the car is not doing right.
Springs and sway bars are pretty cheap, shocks aren't, but if you have money left over I'd invest in rear LCAs w brackets, an adj. panhard rod w/ brackets, strut STB, wonderbar, TQ arm and maybe some camber/caster plates. Kinda depends on how much racing vs street time the car will see. I consider each mod carefully and get a lot of opinions on who are the best mfg.
You can'y be too hasty with this stuff.
Old Dec 2, 2005 | 12:03 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Originally posted by z28z34man
Any more opinions
GO WITH THE PRO KIT!!!
Trust me, the 1" it says it lowers(less if stock springs due to saging) they are awsome and you will have no problem with them. Hell I got my car in a drive way i thought i never could.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
