How do i change/flush my power stering fluid?
Old Nov 25, 2005 | 11:09 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
How do i change/flush my power stering fluid? was going through the car and i am trying to flush all fluids and could not find a good way to do this. Thanks for the help.
Old Nov 25, 2005 | 11:39 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm stupid and thought you said brakes so DELETE
Old Nov 25, 2005 | 11:56 PM
82knightrider's Avatar
Transmission: TH200C....700R4
mine gets flushed out every week due to a leak
Old Nov 26, 2005 | 12:00 AM
Car: 86 T/A
Engine: HSR 355
Again.. DELETE
Old Nov 26, 2005 | 12:10 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
The way I've seen it done in shops is to suck the resovoir 2/3 empty and then fill back with fresh fluid. Do this 3x total and then turn the wheel full left. Repeat 3x. Turn full right. Repeat 3x...and so on and so forth until all the old fluid is gone.
Old Nov 26, 2005 | 09:55 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
here is what we do at the shop.
brakes:
suck out the master with something like a turkey baster thingie, use a lint free type of close to clean the junk out, fill with new brake fluid
gravity bleed the brakes
then refill
one you have new complete fluid, once a year suck the master out and replace
power sterring:
suck it out with the turkey baster
replace
run car
suck it out again
replace
etc
that works
or take the return line to the pump, place that in a pan, have someone start the car, fill fluid as needed.
tranny:
since most cars have drain plugs, if not invest in one, well worth it
drain fluid
replace fluid (sometimes i put an extra quart or two in = overfill)
start up, run, like 2 mins, turn off
redrain fluid
refill
repate 3 times
or
pull return line off coler, put into a jug (like an old washer fluid bottle)
have someone start car, someone holds line into jug
as car runs
someone puts fluid into tranny and someone watches the jug fill
doe this until just comes out nice and red. may need like 2-3 empty jugs for a nice perfect flush. again this is extreme but it works awesome
you can drain almost 1 gal out then refill too, since you arent driving the car it wont really do harm.
i guess for a transfer case, it could be the same.
the turkey baster at a dollar store is worth it's weight in gold
i like to do this every year on the cars, since it's so easy to do and makes those parts last alot longer
while you're at it dont forget the radiator, overflow tank, and rear diff.
on new cars, fluids are the most important things to change regulary due to the high heat the cars run, and again 95% of new cars have tranny drain plugs, takes 5 mins to drain and refill.
of course on a 700r4 it also never hurts to change the tranny filter.
i recommend doing that, replacing the pan with a dearlee tubed pan, has a drain plug
and fill and drain the fluid like 3 times, you'll pretty much be fully flushed.
i did that method in my Commanche, was BLACK tranny fluid. did that 5 times over 3 months, and now its nice and red, and cleaned out.
every oil change i change the tranny fluids, as a way to flush em out (since i tow the jetskis with the jeeps)
Old Nov 26, 2005 | 11:24 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Thank you so much for the quick responce .
Thanks for the qiuck responces, expecially Don 79 TA
thanks for the complete list, am going to start next weekend, also I have read many threads bout flushing the trany that way, I think that is what i am going to be doing, the fluid is also black. expect that it is the original fluid. Thanks agian.
backtothe80s
Sep 5, 2015 12:39 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
