Rear Axle Bar
Old Dec 2, 2005 | 03:09 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Rear Axle Bar
I removed the bar that runs across the back axle. I think its called a pan hard bar but not sure. It is the original and after I took it off I noticed it has a slight bend on it which couldn't be great. Probably happened over time. I looked in the classic industries catalog and they have listed a 1984-02 Rear Axle Tie Rod (G4659) origninal GM which looks like the bar I took out. They have also listed a1982-02 Pan Hard Bar (AD125). I was wondering whats the difference? The Tie Rod looks like what is on the car already but thats for an 84 onwards and my car is an 82.
Old Dec 2, 2005 | 04:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sounds like one is an original GM piece, where the other is a reproduction piece. Either should work from '82 onward. Probably a typo in the catalog.
Can also purchase an aftermarket panhard bar. Typically stronger.
RBob.
Old Dec 2, 2005 | 10:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Considering how much better any of the aftermarket pieces is, there's no point in buying another stock piece, especially when you have to pay to have it shipped overseas.
Old Dec 2, 2005 | 01:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
just making sure, the panhard rod *should* have a slight curve to it, like a slight smiley face...
(right? )
Old Dec 2, 2005 | 01:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Should be straight.
Old Dec 2, 2005 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
uh oh...
Old Dec 6, 2005 | 04:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mine has a slight curve in it
on the z28
hehe
Old Dec 6, 2005 | 07:29 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
There are two bars. One is a Pan Hard (AD125). This goes from the axle to a mount on the body. This should be straight.
The second bar is called the Rear Axle Tie Rod. It goes from the mount that the PHR attaches to, to the opposite side of the body, it is designed to add strength to the PHR mount. It is usually bent to allow room for the exhaust. Sometimes exhaust shops bend PHR to fit after market exhausts. Make sure your exhaust wont contact your new PHR if it's straight. Remember the PHR moves several inches up and down with suspension so the exhaust has to have good clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
z28addict8490
Aug 7, 2015 08:48 PM
