Preloading rear sway bar?
Old Dec 7, 2005 | 06:38 PM
brutalform's Avatar
Preloading rear sway bars, and how is this done? Is the talk about the OEM style bars, or the aftermarket Wolfe Race Craft style? I have heard of this increasing traction to a degree, and would like to experiment. Thanks.
Old Dec 8, 2005 | 12:41 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Preload. I dont like that word. I think the phrase should be inital weight jack.
To me if I were trying to preload the right rear tire...
I would reduce the size of the spacer on the end link on the left rear.
This would make the left rear sway bar end closer to the chassis.
I would leave the right side alone or either lenghten the end link spacer.
The effect that this would have is to initially put twist or torsion in the rear sway bar.
The right side should now be trying to lift the right rear side of the chassis the same as adding more spring rate to that tire.
The left side should be tring to do the exact oppisite.
You may be able to also adjust the front sway bar the polar opposite to add more spring weight to the left front which would also add weight to the right rear. (anti wedge or reverse cross)
I may be totally wrong about all of the above, but believe that I am correct.
Old Dec 11, 2005 | 06:06 PM
brutalform's Avatar
Thanks for the reply..
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
