How do I know if I have WS-6 for sure?
Old Dec 8, 2005 | 09:34 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Look at the RPOs should be WS6 code if it's a WS6. My RPO list was located in the center console.
Old Dec 8, 2005 | 12:37 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Old Dec 8, 2005 | 01:06 PM
Car: 2 T-Tops
Engine: 327/305
Old Dec 8, 2005 | 01:51 PM
Car: 2 T-Tops
Engine: 327/305
Old Dec 8, 2005 | 03:45 PM
Car: 2 T-Tops
Engine: 327/305
I figured it out! It is a WS-6. There is a little ID plate on the radiator support under the hood...and what do you know it says WS 6 right on it in stamped metal.
Old Dec 9, 2005 | 04:02 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
kentuckyKITT, if you're talking about your '84 Trans Am, check for 32mm front and 23mm rear sway bars and rear disc brakes. You'll know for sure if you have WS6/WY6.
I've never seen WS6 on the "data tag" on the radiator support. I've seen WS4 which is the RPO for Trans Am.
Tas
Mar 13, 2002 06:56 PM
Tas
Dec 11, 2001 05:29 PM
MotorCityMuscle
Nov 15, 2001 09:36 AM
jeff
Nov 7, 2000 12:02 AM
