will these wheels fit?
Old Dec 9, 2005 | 09:35 AM
casebaseball205's Avatar
with spacers or without? car is an 86 firebird.
Brand: Eagle Alloys
Product Line: Eagle Alloys 077 Series Wheels
Rim Diameter (in): 16
Rim Width (in): 8.00
Backspacing (in): 6.125
Beadlock Functional: No
Beadlock Included: No
Rim Material: Cast aluminum
Center Material: Cast aluminum
Wheel Finish: Polished
Lug Nut Seat Style: Conical seat
Wheel Construction: 1-piece
Conical Seat Taper: 60 degree
Hub Centric: No
Center Cap Included: Yes
Offset (mm): +43
Load Rating (lbs): 1,400
Valve Stems Included: No
Quantity: Sold individually.
Wheel, Series 077, 16 in. x 8 in., 5 x 4.75 in. Bolt Circle, 6 1/8 in. Backspace, Each
Old Dec 9, 2005 | 09:41 AM
NHRA427's Avatar
Car: 94 Trans Am
Engine: LT-!
I have 15x10 with a 6in backspace and i have to cut out the inner lip inside the fenderwell. not the outside lip but on the backside of the wheel. also have to have tubular control arms because the tire rubbed on the stock one. They will fit but without modifing inside you will have to use wheel spacers.
Old Dec 9, 2005 | 03:33 PM
i was thiknin 17s....so i would definitly need spacers?
Old Dec 9, 2005 | 06:30 PM
NHRA427's Avatar
Car: 94 Trans Am
Engine: LT-!
diameter isnt a big deal its the backspace that makes the need for spacers. maybe someone else here has done what your wanting to do and has more info
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
