Strange Rear End w/Rear Sway Bar
Old Dec 14, 2005 | 11:04 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
My stock rear sway bar is hitting the newly installed Strange rear end w/ the aluminum cover. The way is hitting against the aluminum cover and the end link holes are not lining up. Has anyone else had this problem and what did you do to rectify the situation.
Old Dec 16, 2005 | 11:12 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Well, i am about to put the strange 12 bolt in my car so I'm sue I will have to deal with the problem too. Spohn sells a kit to make it work but at $75.00 i will see what i can come up with to make it work first. Kit basicly uses larger and longer U-bolts with a larger spacer on the bottom to move the swaybar farther away from the rearend. It also uses longer endlink bolts to match the amount the spacers moved it down. Its on his site if you want to check it out...............jt
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
