Spohn Steering Brace
Old Dec 18, 2005 | 10:27 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
What your option on the Spohn Steering bar? Did you have to make any modification to get it to fit?
Give me the goods and bad about this steering brace...
Old Dec 22, 2005 | 08:45 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i had to cut the lower fan mounting bolt boss off.
its a pain getting a socket in there anyway, with the boss cut off, you can completely see the bolt head, which makes it an easy ordeal with a ratchet wrench, and allows the spohn arm to bolt in.
ive got a 4th gen rad and fans now, so its not in the way of anything.
i think the BMR may be a better fit(smaller bar?) but i have all spohn stuff on my car, so i went with it.
good luck.
Old Dec 22, 2005 | 09:15 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
i have the spohn also, can't to sand the bosses off the fan mounts too, also had to grind the holes a little bigger to get it to fit. I got the spohn cause thats basicly all i have but if i had to do it again i would get the TDS unite since i have read that one fits a lot better.
Justin
Old Dec 22, 2005 | 09:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Justin
i filed the paint off the inside holes, started all the bolts, and snugged them in together.
fit like a champ, but ive heard of having to "waller" the holes out a bit.
Old Dec 22, 2005 | 10:46 PM
DTL504's Avatar
I will have to modify what ever needs it..I went ahead and bought over $500.00 worth of Spohn Suspension parts as a X-Mas present to myself: I already have his LCA and Panhad Rod, Now I just ordered the items below, I was able to get a price match on some these parts...They will be here tomorrow, so I will be in the garage all weekend making things happen.
1. Spohn 82-92 Tubular Steering Brace:
What Color? RED
Item# 995 $60.00
2. Torque Arm Rear Mounting Hardware Kit:
Item# 982 $14.95
3. Spohn 82-92 Adjustable Torque Arm - 700R4/T-5 Transmission
Item# 301 $375.00
What color would you like?:RED
Front Mount Type:Chrome Moly Spherical Rod End
Drive shaft Safety Loop(s): Front Only
Material Type:Mild Steel
4. Aftermarket Rear - Sway Bar Installation Kit
Item: 901- $75.00
5. Front Sway Bar Bushing Hardware Kit (82-92)
Item: 989 $4.95
Total Price: $ 529.90
Old Dec 23, 2005 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The Global West version fit my GM dual electrics without modification.
JamesC
Old Dec 23, 2005 | 07:23 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Agreed.
I didn't have to mess with the fan (maybe because of single fan option?) but I did have to elongate the mount hole on the driver side. It was off by a lot and I don't understands Steve's reason for that. All of his other products are perfect.
Old Dec 23, 2005 | 12:17 PM
DTL504's Avatar
Originally posted by ShiftyCapone
Agreed.
Have anyone brought this to Steve attention so that he can adjust fire and make the neccessary changes?
I doubt that If he knew that he would continue to produce the same defect over and over...
Old Dec 23, 2005 | 12:29 PM
Car: 1991 Camaro
he knows about it cause when i called him about the problem thats what he told me to do.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
Night rider327
Sep 25, 2015 04:19 AM
