Spohn Torque Arm...Help
Old Dec 18, 2005 | 01:39 PM
helrazor's Avatar
Car: 91 camaro rs,92 camaro b4c,1983 cam
Engine: 305 tbi Soon To be 500hp 383,l98,ca
Transmission: 700r4,700r4,turbo 400
I have a 700r4 Spohn Torque arm/crossmember it is installed and all.But when I drive it,it sounds like the driveshaft is hitting something sometimes,not always. It also has the front and rear safety hoops. Can someone please help,thanks.
Old Dec 18, 2005 | 11:42 PM
KillerRS's Avatar
Re: Spohn Torque Arm...Help
I would start by getting under the car and looking at the drive shaft. If its hitting something chances are good you'll notice what area its coming from.
Old Dec 19, 2005 | 07:48 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I had the same issue.
I also had all 6 crossmemeber holes drilled and tapped :-)
Anyhow, make sure your only using the original 4 holes, and then just loosen it to tweak the driveshaft loop until its dead centered in the tranny tunnel.
This seems to be the issue about 80% of the time. Just re-center it and check it out.
U chould be good to go
later
Jeremy
Old Dec 19, 2005 | 08:08 PM
helrazor's Avatar
Ok ill try that thanks
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
