Strut Mount Problems
Old Dec 26, 2005 | 06:05 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Came out to my car to do an oil change and found the strut mount like this. I had the car aligned a year or so ago when I lowered it. No accidents or anything. Is this just caused by loose bolts? You can see where it should be from the dirt marking.
It okay to just loosen and reposition?
Old Dec 26, 2005 | 06:43 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Prolly wasnt tight enough and worked loose going thru a pot hole or something.
Slide it back and if it doesnt pull, it'll be fine.
Old Dec 26, 2005 | 06:46 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That's what I figured. Went ahead and put it back in the old location. The actual housing seems to be a little bit bowed up; that alright as well?
Old Dec 27, 2005 | 07:05 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
strut mount
I agree with justin but if you are still spooked by it you can buy the upper strut mounts in a pair for $20 used plus shipping, I just bought a pair for that same price I quoted. As a matter of fact
I'll sell ya mine LOL, really they are cheap enough so as to not
cause any sleepless nights.
Old Dec 29, 2005 | 11:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If I were you, I'd go get an alignment quick. Let them know what you think happened. When you get the car back and they say "OK, it's good", put a torque wrench on those nuts and make sure they're tightened to spec before you leave.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
