4x4 Firebird
Old Dec 29, 2005 | 10:00 AM
BIRD-VERT92's Avatar
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
4x4 Firebird
I am building a v8 for my v6 powered 92 firebird vert. I need to put new springs in the front during my front end rebuild. If I go ahead and put the heavier v8 springs in now before I swap the engine, is it gonna look like a 4x4 in the front end? Who makes progressive rate springs, as I assume these would not affect the ride heigth as much.
Old Dec 29, 2005 | 11:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Regardless if it is a progressive rate or linear rate spring, it won't matter. You should only use a V8 spring if the car has a V8. Otherwise your car WILL look like a clown car. Keep the V6 springs in your car until you' ve swapped in the V8.
Lon
Old Dec 29, 2005 | 11:23 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just curious why would you swap the springs first?
Old Dec 29, 2005 | 11:30 AM
Engine: 388ci
I am going to be changing ball joints and A-arm bushings, so I will have the springs out anyway. I need to get an alignment afterwards. I figure I would have to have it re-aligned if I changed the springs later. Just trying to be effecient.
Old Dec 29, 2005 | 12:09 PM
lonsal's Avatar
I understand why you'd want to do it at that time. It would make sense if you had the V8 ready to swap in. Can you hold off on the front end rebuild until the V8 is ready to swap into the car?
Lon
Old Dec 29, 2005 | 12:18 PM
Engine: 388ci
Yeah I might wait until then to do it all. I'm just getting cabin fever this time of year wanting to do the work that I have parts for now. I probably will have to take the A-arms loose again anyhow to relocate the engine mounts on the frame. I know it can be done without removing them but that requires a lot more patience and rubber fingers. Thanks for your help guys.
Old Dec 30, 2005 | 12:51 AM
iroc22's Avatar
Re: 4x4 Firebird
I dont think any aftermarket company makes progressive front springs for a thirdgen. And it wouldnt really affect the ride height, only the quality and the way it acts.
In any event, do yourself a favor and keep the V6 springs for the V6.
Old Dec 30, 2005 | 12:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
We kept the V6 springs in my GF's car when we did her 350 TPI swap. Car handeled very well. I said heck with it and reused them. Heres some pics of it with the 350 and V6 springs.
Old Dec 30, 2005 | 12:35 PM
Engine: 388ci
Looks great to me. Man, what does your GF do to you to make you want to do all that work to her car.
Old Dec 30, 2005 | 02:23 PM
kevinsux's Avatar
Car: camaro
Engine: v8 garbage
Transmission: crap box auto
i bet it involves swallowing.
Old Dec 30, 2005 | 07:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I nearly lauged coke all over my monitor 'cuz of that...
I think that'd be a fair trade though...
Old Dec 31, 2005 | 01:48 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
It took me by surprise as well, WOW.
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
