Just hit a curb
Old Dec 31, 2005 | 03:19 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Just hit a curb
Cracked a rim etc,...
My right side tire is now 1" further back than it should be, and my toe out on that tire is like 5% out from straight.
What specific damage should I be looking for underneath when take a closer look?
All the right side body panels appear to line up still, as well as the hood etc...
Old Dec 31, 2005 | 08:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Bent A-arm
Ripped upper strut mount
bent strut
bent spindle
Damaged Ball joint
Check the mount points where the a-arm goes to
Check all the "frame" and see if you see any creases, or rips that are fresh looking (no rust yet).
Old Dec 31, 2005 | 11:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
same thing happened to me a while back. bent the rim, the spindle, the motor support was tweaked, bent the a-arm rear most bolt, and the frame as well. i hope it does go better for you.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
RS Reaper
Sep 27, 2015 07:04 PM
