4th gen Rear end swap Write up
Old Jan 8, 2006 | 12:51 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Hey everyone i just created this and its a work in progress, let me know what im missing or what i should change. its inteded to help all the beginners out there. More write-ups and information will be added shortly.
http://www.mnengine.net/BC/index.php
Thanks,
Brandon
Old Jan 10, 2006 | 05:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
sweet thats a good piece of work! i'm thinkin of doing the same thing wheni swap in my new 4th gen rear. i made a thread with alot of info in it on the specs of the 4th gen rears and all the swap info like what will fit, what needs to be changed, etc etc.
combing the that post by me and yours will make for a great thread. i still need to work on mine tho, needs organized and such
Old Jan 13, 2006 | 11:45 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Looks good. Only thing I noticed you said was the rear has 3.53 gears...since when did they make that? 3.42 maybe?
Old Jan 21, 2006 | 03:46 PM
1bdbrd's Avatar
Car: 1991 Trans Am
heres a few things i noticed. theres no such thing as 3.53 gears. if everything in the rear is stock then you have 3 options for gears..if it was a 6 speed your ONLY option is 3.42. if auto you can have either 3.23 or 2.73 gears. next the wonder bar is not anywhere near the rear end. it attaches to the front subframe near the steering rack. what youa re talking about (the diagonal bar that attaches to the rear end and to the frame is the panhard bar. and what you call the panhard bar (attaches to the rear and to the tranny) is the torque arm.
good write up though. you may want to put together a list of parts that can be upgraded at the same time since everything will be out like stainless steel brake lines, rotors (brembo blanks are some of the best stock replacements), pads (some from the hawks line of pads are great as well) and any mods to the rear end itself like lower control arm relocation brackets, lower control arms, pahnard bar, bushings, fluid, gears posi ect. that way the job is done once and done right the first time.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
