loose steering column at tilt
Old Jan 9, 2006 | 01:51 PM
chad1966's Avatar
Car: 1989 RS Camaro
Need some advice please.
My 89 camaro has a loose steering column at the tilt mech, actual steering wheel is tight. Was receipt in car from previous owner that just said " steering wheel tightened", so I'm wondering if this has happened before and is loose again.
I've seen the posts about the loose screws that seem to be located a mile in the steering column. Doesn't look like something I want to try without some help.
First, is this dangerous? Will I loose steering soon or do I have a while?
And Second, is it just easier to replace the steering column with one from a salvage yard? Called a salvage yard, said only 89 would fit and wanted $120 for it.
Thanks for any help/info provided!
Old Jan 16, 2006 | 09:55 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Not that hard to repair the column, remove wheel, t/s switch, ignition switch, pull tilt pins out, there are three external torx screws that are the problem, pull them out 1 at a time, install loc-tite and reinstall, not bad to do at all, first time took me about 2 hrs, now I can do it in like 30 minutes. If your not sure ask any GM mechanic, if he has been around for any time at all he knows what it is and how to repair it. Good Luck!
Old Jan 16, 2006 | 10:56 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Fix it instead of replacing it, use the blue stuff on the bolts too. I say fix it because if you replace it the replacement will probably become loose itself someday.
1992Z28!
Nov 19, 2015 07:33 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
