best all-around setup?
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
I have been searching around for a while and haven't quite found what i'm looking for. I would like a setup that can handle a monthly trip to the strip, track, and be driven daily. I know i have a 16 year old car and a front end rebuild is neccesary. I was going to get spohn's front end rebuild kit, eibach pro kit, koni yellows or blisteins, tubular k and a-arms, bigger front and rear sways, lca's(tubular and w/poly bushings) and lca relocators, torque arm (adj), panhard(adj w/poly bushings), aluminum driveshaft, spherical upper strut mounts, tds wonder bar,and alston sfc's. I think this would perform all around but haven't found anyone that is running this setup. I would also give up a more on the strip than street & auto-x if i had to. I understand that everyone has opinons on the best brands but i think, even though he's pricey, i will be going to spohn for almost everything. I am not going to run out and buy all this stuff without asking you guys first though.
Is any of this unneccesary?
LT1Formula
Oct 8, 2015 08:34 PM
