How strong are wheel spacers?
Old Jan 28, 2006 | 10:24 PM
FAST86IROC's Avatar
Car: 86 iroc
Engine: 350 w/ lots o mods
I've heard good and bad things about wheel spacers. Should I be woried about the strength of them?
Old Jan 28, 2006 | 10:58 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Wheel spacers aren't a problem, lug bolts are. You can't put like a half in. spacer behind the rim and expect the lug nuts to grab as many threads. You'll need longer stronger lug bolts.
Old Jan 29, 2006 | 12:05 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Not meaning to hijack a thread...but can you put longer studs into the front floating rotors if you are wanting to use spacers? I know you can in the back.
Old Jan 29, 2006 | 05:16 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Just in case you didn't know, the 2" thick spacers everyone talks about on here are a "bolt on" design and are as strong as stock since the lugs are loaded just like a regular wheel is. Like mentioned here anything more than a 1/4" slip on spacer is asking for trouble.
Old Jan 30, 2006 | 08:43 AM
BMmonteSS's Avatar
Car: 84' Monte
That may be the proper term, but it's hardly used around here.
Whata69
Mar 2, 2016 06:34 AM
Amillionoh7
Sep 11, 2015 11:36 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
