strut question
Old Feb 14, 2006 | 09:32 AM
tph87's Avatar
Car: '87 iroc z-28 5.7 tpi
Engine: 5.7 tpi
Transmission: auto
strut question
after i bought my car i was looking under the hood and i noticed that it looks like someone has moved the struts back a few inches because you can see where they use to be.
is there some reason for this? maybe its not a big deal, i dont know?
Old Feb 14, 2006 | 05:03 PM
brutalform's Avatar
The car probably recently had its front end aligned. I would at least look it over, to see if anything is out of align. (evidence of an accident), just to make sure it is safe.
Old Feb 15, 2006 | 02:56 PM
tph87's Avatar
Engine: 5.7 tpi
Transmission: auto
everything is safe and aligned properly i just thought maby there was some trick i never heard of before.
thanks
Old Feb 15, 2006 | 03:49 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
A few inches? How could that be? Your'e talking about looking at the strut tower covers on top of the fender wells, right?
They do move if you loosen the three hold down bolts. And they could be moved during a wheel alignment, but not nearly that much... more like +- 1/4 inch. The entire length of the position adjustment slot is about 1 inch.
Old Feb 16, 2006 | 03:53 PM
tph87's Avatar
Engine: 5.7 tpi
Transmission: auto
sorry i wasn't 100% accurate
it might be about 1/2" im not shure, i would have to go out in the shed and take the cover off and look.
Old Feb 16, 2006 | 06:22 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
that amount would not be unusual.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Apr 25, 2017 07:14 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
