Might want a bigger tire.
Old Feb 14, 2006 | 02:55 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Ok well stock my car came with the 215/65/R15 and I think I may want something just a little bigger. I thought about going with a 225 all around. I just wanna knows whether to go after a 225/65/r15 or to go after a 225/60/r15. I do not want the sidewall to be any higher than stock and i know the sidewall at 65 for the 225 is bigger than the 215. What do you think I should do guys? I really dont wanna throw off my speedo. Thanks guys.
Old Feb 14, 2006 | 03:00 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I really liked 235/60/15
Old Feb 14, 2006 | 03:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
235/60R15 really looks good on these rims.
Old Feb 14, 2006 | 04:45 PM
Engine: LB9, LB9
Will it rape my speedo?
Old Feb 14, 2006 | 04:47 PM
1st3rdgen23's Avatar
Car: 1990 RS
Engine: 305 tbi (currently)
Transmission: B/W 5spd
i use 245/60-r15 BFG's and they look freaking awsome imo
Old Feb 14, 2006 | 05:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
No, it is same diam. as stock.
Old Feb 14, 2006 | 05:53 PM
Engine: LB9, LB9
so the 235 will go on the the stock RS wheel with no probs?
Old Feb 14, 2006 | 06:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
No problems. It is the same diam as stock, just a bit wider of a footprint.
Old Feb 14, 2006 | 07:44 PM
Engine: LB9, LB9
Should I run the 235's on all four corners or should I run smaller on the front?
Old Feb 14, 2006 | 07:58 PM
Shagwell's Avatar
Car: projects.......
I'd run the 235/60's on all four corners.
Old Feb 14, 2006 | 08:25 PM
Engine: LB9, LB9
I hope if I upgrade from the 215/65/R15's (I think they are the stock size) to the 235/60/R15's that my handling will improve alot.
Old Feb 14, 2006 | 10:30 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it will improve a bit...and if you run some decent springs, and shocks/struts, you'll see even more improvement!
and don't forget about the little things like running poly bushings on your sway bars (it doesn't cost much and works REALLY well!)
Old Feb 14, 2006 | 10:56 PM
Stevo's Avatar
Car: Pair of 92 Z28s
it will feel less boat-like but not too much...upgrading to factory 16" camaro wheels with a 50 series tire will help a lot more...better yet some 40 series tires with 17s...but ya lower series tire to a point will really help handling.
Fronzizzle
Feb 9, 2017 09:31 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
sjorgens
Oct 1, 2015 07:54 PM
rubyred88
Sep 17, 2015 02:19 PM
87hellbird
Sep 14, 2015 05:08 PM
