s10 gear box vs camaro p/s
Old Feb 16, 2006 | 12:32 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
Easy swap ... grind s10 box mounting ears pads flat grind the sway bar braket interchange the pitman arm
Old Feb 16, 2006 | 02:56 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Is that so you can change to manual steering?
Old Feb 16, 2006 | 09:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I didn't grind the mounting ears on my S10 box and I don't have a sway bar to get in the way. I did use the third gen pitman arm though to keep the same steering geometry.
You need a 84 and up S10 box. As in the above picture, it has 4 bolts on the top cover. The earlier boxes have 3 bolts on the top cover. Although I haven't checked, the input shaft and sector shaft should be a different size making the swap a little more difficult with an early box.
The manual steering box can be found in S10's that originally came with the Iron Duke 2.5L 4 cylinder engine however not all 4 cylinder S10's came with manual steering.
jklein337
Sep 19, 2018 06:23 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
mcquigg
Aug 13, 2015 02:26 PM
