what type spacers do i need
Old Feb 18, 2006 | 08:57 AM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
i am wanting to run these wheels and 315's on back 275's on front http://cgi.ebay.com/ebaymotors/AFS-C...QQcmdZViewItem what type and size spacers will i need i dont care where they hit i have a hammer. these are mostly for drag in the street class. my car is for track mostly and very little street. btw i have a third gen rear drum brakes for now.
Old Feb 18, 2006 | 03:43 PM
91drag's Avatar
Engine: 350,289
anyone i like the way shagwell's car looks
Old Feb 18, 2006 | 10:12 PM
91drag's Avatar
Engine: 350,289
ttt
Old Feb 19, 2006 | 10:27 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
If they're for mostly drag racing look for a different wheel. Those are heavy and will have too little sidewall. Not to mention your tire choices are going to be limited.
Old Feb 19, 2006 | 11:55 AM
91drag's Avatar
Engine: 350,289
so would telestars or somethink like that be better what size backspacing. ive seen most are running 15x8 with 5.5 bs or 15x10 with 5.5 bs. in the class i run i can have up 10.5 wide slicks or 13.5 wide street tires. i have 4.10 gears and 26 x 8.5 et drag right now looking to going to 28x 10.5 soon.
Old Feb 19, 2006 | 12:20 PM
Dialed_In's Avatar
If you're allowed to run drag tires and skinnies in your class then go for it. Where I race, the street class is only allowed DOT tires and front wheels must be full width, no skinnies.
You need to calculate what tire height will put you through the traps at your desired RPM. For example I knew I wanted to trap around 5400 RPM based on my dyno results so with a 4.10 gear in third with 5% converter slippage that put me at 28" tall tire.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
bjpotter
Oct 4, 2015 07:48 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
