formula rear springs removal..help
Old Feb 20, 2006 | 06:10 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello all,
I have a 1989 Firebird and would like some pointers on how to remove and install the rear springs? Any information will be greatly apprecated.
Brad
Old Feb 20, 2006 | 06:23 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
put the car on stands and put a jack under the center of the rear. Take the bottom shock nuts off and lower the rear down. The springs will fall out
Old Feb 20, 2006 | 06:32 PM
brutalform's Avatar
When you reinstall them, or the new ones, make certain the rubber spacers that go on the top of the springs fit the top coil correctly. Basically, they fit one way, and are formed to the top coil.
Old Feb 20, 2006 | 07:01 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Ok sounds like a good plan, stupid question, where on the rear do I put my stands, I have always put them on the axle.
Old Feb 20, 2006 | 07:04 PM
Dialed_In's Avatar
On the frame rails, in front of where the control arm bolts to the rail.
Old Feb 20, 2006 | 10:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's not *quite* as easy as written (when is it??)
when after unbolting your rear shocks, and lowering the axle with your jack, the LCA's should rotate, but you'll have to watch your TA. Once you have the axle as far down as possible, you should be able to yank the springs out. Not a ton of force, but mine didn't 'fall out' that easily.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
AkDrifted
Aug 17, 2015 07:45 PM
