suspension swap
Old Feb 28, 2006 | 03:02 AM
96-84lt1's Avatar
suspension swap
Hay im mike
A buddy of mine has a 96 formula firebird that he wreck. Well i just boutgh an 84 firebird for a bout 300 bucks.
He has a complete car with an lt1 and six speed. lowered exhasust and complete wirering harnes and everyhting.
I wanted to no if anyone has tried swaping any suspension compenets.
and if its possible how did you do it.
Old Feb 28, 2006 | 05:53 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the drivetrain is not a problem.
the suspension on the other hand is not going to "bolt in." I don't think you would even be able to fabricate a way to get them to work. The strut assembly and upper and lower control arms are completely different.
Old Feb 28, 2006 | 01:41 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Rear suspensions are the same. Front suspensions are completely different.
Old Feb 28, 2006 | 05:58 PM
Shagwell's Avatar
Car: projects.......
The rear is exactly the same, other than the possibility of the reversed torque arm. (tabs point different directions in different years) - Unless he's got aftermarket pieces, the only thing you'd be gaining is the age difference of the bushings.
- The front on the other hand, is completely different. You'd have to change/fabricate basically the entire front clip.
- The drivetrain is a simple swap. - damb...I wish a 6-speed would fall into my lap... - The rear differential is wider than a 3rdgen unit, I can be run easily, but requires the 4thgen offset rear wheels.
- As for the exhaust, the intermediate pipe, y-pipe, and headers are different. Possible, but it'd take some fabrication...
Old Feb 28, 2006 | 11:35 PM
96-84lt1's Avatar
so basically they just changed the front and not the back.
Are the motor and transmision mounts the same for the v8
Old Mar 1, 2006 | 11:39 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Motor mouts are the same. If you swap a 4th gen trans into a 3rd gen, you will need the thrid gen crossmember, which you should already have.
Old Mar 2, 2006 | 01:06 AM
96-84lt1's Avatar
Kool so it sounds kinda easy
has anyone tried switching 4th gen and 3rd gen interiors
Old Mar 2, 2006 | 02:40 AM
1981LT1's Avatar
Engine: LT1; LT1
the seats should actually bolt right in. I am in the middle of converting my 86 to a 4th gen interior. I have been told it is a bolt in procedure.
Old Mar 2, 2006 | 11:39 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
I know the dash swaps out to but you have to cut the 4thgen one a little. Looks okay IMO, I like the 3rd gen dash better.
Old Mar 2, 2006 | 07:26 PM
Shagwell's Avatar
4th gen seats are bolt-in. the dash takes some work, especially if you want to retain your a/c...as I did.
- yes, my cage is slightly crooked, the area it's weld to is gone...more convertible mount rust...yet another reason I'm going full-frame... - thats all from me, this is getting too far from chassis/suspension
Old Mar 2, 2006 | 07:51 PM
96-84lt1's Avatar
excaktly wat is a lil work
Old Mar 3, 2006 | 12:00 PM
Shagwell's Avatar
...hummm... I've built/designed several complete chassis, and several front/rear clips, so i classify the dash swap as a little work. - Proper install with functioning a/c took me about a week. That being weekdays after work and a full weekend. I also re-wire while I was there simplifying a bunch of crap. 2 of the screws at the winshield screw right in, the rest your on your own. Those 2 screws get yas centered though. You have to trim the front panel shorter and to the angle of the 3rd gen windshield/firewall. - It's also about 3/4" shorter on each side, so you have to put in some small filler panels. - I wanted the 4thgen mounting location for the fuse panel, so that took some work also.
customblackbird
Aug 15, 2021 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
cam-mike
Aug 24, 2015 07:23 AM
