Dammit!!! something snaped and now the rear sways!
Old Mar 4, 2006 | 01:06 PM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
Transmission: Built 700R4
Last night I was @ a dead stop and I turn right and accelerate just a lil bit and SNAP something made a huge noise....there was construction so at first I thought I might just have ran something over but today I started to notice that when shifting gears the car seems to sway all over starting from the rear.....and when going at a constant rate of speed then accelerating more the sway motion happens again...
Any Idea what may have happened? Im gonna check under the car today later on.
Old Mar 4, 2006 | 01:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Panhard bar,LCAs,Maybe endlink(swaybar),etc
Old Mar 4, 2006 | 08:06 PM
klumb15's Avatar
check the torque arm mount also. its right where the torque arm is bolted to the tranny. Very possible you just ripped the cheap little GM mount there...that will feel like there is a wet noodle holding the rear end in square...
otherwise just jack that thing up and check all the mounting spots on all of the suspension components...not hard, takes a matter of a couple minutes...
Old Mar 5, 2006 | 05:07 PM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
hmm....the noodle portion sounds correct....when I lift the car tommorow I hope that thats the problem and not the rear end.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
