who has intrax?
Old Mar 19, 2006 | 10:43 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
who has intrax?
i just got my intrax springs in this week and i am very happy with them but i would like to bring the front up about a 1/2". any ideas? and what have you guys done with you bumpstops? anyone use those energy suspension short ones?
Attached Thumbnails who has intrax?-new-iroc-pictures-16   who has intrax?-new-iroc-pictures-13
Old Mar 20, 2006 | 09:25 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I can't help with the raising of the car, but I can tell you what I did with the bumpstop. When you look at the bumpstop it has a step to it. I cut off the upper part with a buzzsaw. before I did this I kept bottoming out on the bumpstop. I intend to replace them with poly pieces when I can. Do you like your springs fairly well, i have found mixed opinions on them?
Old Mar 20, 2006 | 09:51 PM
Car: 88 IROC
so far i like them. i love the stance but like i said b4 the front is a little low. id like it to come up about a 1/2" maybe. they handle alot better than the irocs i had. what are your mixed opinions?
Old Mar 20, 2006 | 10:33 PM
Gr89RS's Avatar
Car: '02 Z06
I really like the stance you've got, may I ask what profile tires you are running?
Old Mar 21, 2006 | 10:06 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I love the way they make the car look and the handling is greatly improved. Like you I also wish the car sat a little higher.
Old Mar 23, 2006 | 03:31 PM
Car: 88 IROC
the tires are 245/45/17 all around i should have got a little bigger tire in the back but with these i can rotate them which was the major +, and i havent seen many people running intrax springs and different tire sizes. i thought the drop would be level but it sits up a little higher in the back.
Old Mar 23, 2006 | 04:00 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
I had a set in intrax springs on the front of my car. I left the rears off for that nose down look. They were really stiff and I actuall wrecked my bump stops and have hit the cross member numerous times once at 40 mph and put a slight indent in the bottom of it the front tires were 225/50/R15s anyway I took them off when I started to restore the car and have since gone to an air suspension
Kyle F
Feb 5, 2001 09:23 AM
AaronRS305
Jan 12, 2001 05:36 PM
REVLIMIT
Jul 26, 2000 03:00 AM
