Question about Intrax 2" lowering springs......
Old Jan 8, 2001 | 12:31 AM
AaronRS305's Avatar
Im sorry if this has been asked before, but I have 245/50/ZR16 tires on my car, and i want to get the INTRAX 2" lowering springs. Would I have any problems with the tires rubbing on the inside or top of the fenders or anything?
1992 Camaro RS L03
Old Jan 8, 2001 | 04:43 PM
jz28's Avatar
I have them on my '82 Z28 with the stock 15in wheels. 225/60 R15 tires. I haven't had a problem with rubbing but I drive very slowly over speedbumps,drive ways etc... I feel its a little to low for daily street use. But I love the way it handles
Later
Lason
Old Jan 8, 2001 | 11:51 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
My brother has a set on his RS and he only has the 15" rims and doesn't have any problems rubbing or bottoming out.I don't know how the 16's are going to be,but with my 17's,my car is lowered about 1 3/4" without any problems.I'm running 275/40's.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood
Flowmaster cat-back
TBI mods
383 implantation soon to come.
Old Jan 9, 2001 | 09:56 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
you shouldn't have clearance problems if the stock wheels fit,when you move up in rim size,you use lower prophile tires keeeping the wheel diameter the same.
Old Jan 9, 2001 | 10:06 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The diameter isn't what you have to worry about, it's the width. I have 295/50r15 in the back, but with a stock ride height. I want the Intrax, but I probably will have to change tire sizes though.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Jan 12, 2001 | 01:34 PM
MelloYello's Avatar
What Kind of shocks and struts do you recommend using with these springs...I want a long life, rebuildable unit that will not bottom out due to lowering
Kyle
1990 Firebird Formula 350 speed density TPI; K&N, air foil, throttlebody coolant bypass, underdrive pullies, MSD 6AL, MSD HEI coil, 8.8mm wires, adjustable fuel pressure regulator, Hypertech Thermomaster chip, 160* thermostat, fan switch, B&M stage 2 shift kit, Edelbrock 1&5/8 headers, gutted dual cats, Flowmaster 80 series muffler, 3.73 posi rear end
Old Jan 12, 2001 | 05:36 PM
MelloYello's Avatar
anybody?
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
