is my swaybar bent?
Old Mar 21, 2006 | 11:26 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
is my swaybar bent?
well i was spraying some undercoating around and noticed that the swaybar has a dip in it... i cant remember if its supposed to be like this.
is it bent?
Old Mar 21, 2006 | 11:31 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
thats ok there all like that
Old Mar 21, 2006 | 11:36 AM
Car: IROC Z
Engine: 5.7
ok good thanks
Old Mar 21, 2006 | 06:01 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Wheres your air dam?
Old Mar 21, 2006 | 08:09 PM
Car: IROC Z
Engine: 5.7
ya.... about that.. see this traffic light pole jumped in front of me. very sad. nothing i could do. cant find a decent replacment.
Old Mar 21, 2006 | 10:44 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
what does an air dam look like?...i just installed a TDS wonderbar and i didn't see anything that i thought was an air dam...
Old Mar 21, 2006 | 10:46 PM
Car: IROC Z
Engine: 5.7
its a plastic flap that hangs off the bottom of the radiator
Old Mar 28, 2006 | 03:01 PM
Car: 1988 SC Camaro
Engine: 305 TBI
ohh ok, you mean that platic peice that looks ugly and does absolutely nothing...no wonder why i took mine off...
Old Mar 28, 2006 | 03:12 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
That useless piece of plastic creates a low pressure area behind the radiator and keeps your car cool. Without it air has no reason to turn up into the radiator. These cars are "bottom feeders" without the air dam you'll have problems at highway speeds keeping the motor cool.
Old Mar 29, 2006 | 01:01 PM
Shagwell's Avatar
Car: projects.......
exactly. I fixed the "cooling issues" on so many of these by simply putting it back on its funny. - Did you think GM put it on to be like a curb finder or something??? its called profit, they don't design/install anything you don't need....
Old Mar 30, 2006 | 02:54 AM
Car: IROC Z
Engine: 5.7
anyone know where i can get one of those? i cant find a good one from the wreckers. although are the v8 ones different?
Old Mar 30, 2006 | 06:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you know, it's funny, i have a sport coupe and my buddy has a berlinetta...neither of us have the air dam (actually both cars were air-dam-less when we brought them home) and they stay cooler than my gfx car did with the air dam...funny huh? think those slots in the front of the nose are doing anything?
Old Mar 30, 2006 | 07:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Air dam is not specific to the Engine - it's specific to the nose. There is a left and a right side piece, unlike the 3-piece Z28 design. Be sure to look for one from another 85-86-87 Sports Coupe, LT, or Berlinetta because that is the only style
Old Mar 31, 2006 | 09:22 AM
Car: 1988 SC Camaro
Engine: 305 TBI
I took my airdam off a couple years ago, I've never had a heat problem...in fact, my car actually seems to run a bit on the cool side...maybe it depends more on the car itself...the only reason for taking it off was to stop it from scraping over bumps or going up a steep road from a flat surface...and also beacuse from a distance it didn't look good in my opinion
Old Apr 26, 2006 | 11:32 PM
Faded's Avatar
Car: '91 Firebird
The air dam can still be found over the counter at GM. Search for part numbers. I think I paid around $30 for mine a couple years ago.
Old Apr 27, 2006 | 07:41 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
There are two different senders used for measuring the coolant temperature. One for the computer and one for the guage.
Hook up at Tech 1 to the ALDL and its common to see two completely different coolant temperatures.
Your 'cool' running engine might no be running so cool. Then again, your overheating engine might not be overheating at all either.
Old Apr 28, 2006 | 09:05 AM
kaptinkafeen's Avatar
How do the funcional properties of the airdam change when a thirdgen is lowered say in the range of 1.5-2.0"? Does anyone know? With less "space" between the ground and the underside, is the airdam still effective? Just wondering how the change in ride high would effect the pressure differential created by the airdam - I'm no areodynamisits This is why I ask - I hope it isn't a stupid question....
-Andrew
dbrochard
Oct 3, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
RedLeader289
Sep 23, 2015 06:50 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
