rod ends vs poly bushings...
Old Mar 25, 2006 | 10:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
For the tubular a-arms, is there a noticable difference in the ride quality and noise between the two? I know that the rod ends don't bind as much, but I don't know if that is worth the extra $100 and the road noise.
Old Mar 26, 2006 | 12:37 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Rod ends don't last very long. From constant use, they'll become worn and sloppy. A street car should consider changing rod ends every few years. Poly or rubber bushings should last the life of the car.
Old Mar 26, 2006 | 09:08 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I hadn't thought about that. My panhard bar has the rod end on one end and I think it is starting to get sloppy. Doesn't feel the same as it used to. I may have to replace it.
Old Mar 26, 2006 | 06:43 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
ANY advantage in using rod ends rather than bushings ?
Old Mar 26, 2006 | 07:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Advantage? An almost solid suspension component. Won't compress or flex like rubber or poly bushings. You shouldn't need rod end suspension components unless you have a full race vehicle.
My ladder bars have rod ends. My panhard bar has rod ends. My front tubular a-arms have poly bushings.
Old Mar 26, 2006 | 09:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I think I will get the bushings on the rest of the stuff, except for the LCAs. They move alot. If I were going to only race the car, I would use the rod ends, but driving it wears out the rod ends and I don't want to have to spend the money every year to buy new ones.
Old Mar 26, 2006 | 10:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Although I have no facts, good rod ends on a daily driver should last about 5 years before needing replacement. I guess it all depends on how much mileage the car sees and how much abuse it gets. Basically, you replace them when they get worn just like any other suspension component so it's just something else that needs to be checked at least on an annual basis.
At least a rubber or poly bushing will last a long time.
customblackbird
Aug 15, 2021 10:16 PM
Warlocksirix
Sep 3, 2015 12:26 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
