Air Ride CoolRide suspension on a 3rd Gen?
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I've been thinking about saving up for this suspenson setup since for starters I can get it for about $650 (front and rear) and it'd be nice to get my car to handle better than it already does. Does anyone have this setup on their third gen that can give me opinions on it? If I can only buy one at a time, would it be better to get the front or the rear first?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Just so you know that 650 that you are planning to spend will double when you purchase a compressor. When I was planning this as well, I was so surprised on how cheap it was. Little did I know it came with everything but the compressor. If, somehow, you are getting EVERYTHING for 650 let us know how and where because I would jump on that like flies on ****!
Car: 2012 Corvette
Engine: LS3
I'm not getting the compressor and selenoids and all that, partly because I don't want all that and don't need it either. I called Air Ride and they said that I just need to buy 4 inflation valves and the air hose and it'll be good to go.
it is a good kit, probably the best kit out...
i'm gonna do what your doing this winter i think, and then purchace a compressor sometime during the summer of '07..
i don't think it would really matter which one you got first if you want to buy them seperate...i would probably do the rears first myself...
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
How do the car really handle with these kits? Will one get the option off stiff versus soft springage in these? I'm just very curious if this is any way to go if one wants performance handling or not...
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
so what all comes with the kit? does it replace just the springs or springs and shocks? that would be pretty cool and just have some air nozzles all together in the hatch area. i wish i would have known about that b4 i redid all my suspension. ive got about $500 in mine.
i believe the front comes with shocks, not sure about the back tho...
you have 500 into just the springs and shocks? because if you have money into like a panhard bar, torque arm, control arms, you can still use them, and they will help that much more...
Car: 88 IROC
no i have about $500 in springs and shocks. i have $200 intrax springs and the struts were $130-150 for the front and the shocks for the back were about $75-90. so i would have definitely done the air suspension... i was unaware that you could get it for that cheap with out the compressor.
does anybody know about the shock situation? does the kits come with them or what? I'm pretty sure the front does, I wasn't sure about the back. I like my drag shocks that I have, so thats why i was curious...
Car: 87 iroc 89 pearl white' black 06gto
Engine: 350 Procharged AFR, T76 383 miniram
Transmission: 700r4, 700r4, LS2 t56
does anybody tried using the cool ride front kit with an aftermarket kmember and tubular control arms?? i just got my front and rear cool ride kits
okay...
doesn't the front come with a shock relocation bracket or something? i remember reading something about a shock in the kit...haha
And click Part # arf6700 this are the instructions of the kit that i have (fronts) is a PDF file
the rears Air Ride Technologies CoolRide Kit and ShockWave System the rear kit works with 3rd gen and 4gen.
Car: 2012 Corvette
Engine: LS3
Damn Maroon, your car looks damn good!
Oh ****, I'm gonna have to cut the spring pocket on the front. Dammit.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
how are you going to inflate and deflate the bags without solenoids and a compressor?
Car: 2012 Corvette
Engine: LS3
I would do a google advanced search for more info here. There are guys here running airbags and there is ALOT of information in their posts but the search function is broken so google is the best bet. Just go advanced search, specify thirdgen.org in the domain field and type in the search terms.
search works fine....heres a list of a bunch of threads using 'airride' as a keyword
https://www.thirdgen.org/forums/sear...searchid=10096
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
