Coil Spring Isolators?
Old Mar 28, 2006 | 08:52 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
I'm going to change my springs this weekend but don't know anything about the spring isolator. I read some where that they lift the car some what which I don't want. Do I have to put them on? If so can I get them at my local auto store?
Old Mar 28, 2006 | 10:12 PM
Guest
Guest
Posts: n/a
Should already be in the car now. They are on the top of the spring, might fall out when you pull the old springs. The rears are thicker than the fronts, fronts are little more than a thin piece of rubber.
Old Mar 29, 2006 | 12:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The rear isolators may lift the car (I've read the replacements are for fourthgen cars), the fronts won't.
JamesC
Old Mar 29, 2006 | 03:43 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Ok, so i should just use the same one's that are already on there?
Old Mar 29, 2006 | 04:00 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Or you can do what I did and toss the thick isolators and push a 12" length of heater hose onto the top coil of the spring. It'll lower the rear of the car about an inch.
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
