Stock Replacement Spring Info
Old Mar 29, 2006 | 10:37 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Heres a list of all stock replacement springs from Moog for our cars. I didnt note the application of each.
If you want to know the spring specific for your car
1. Click here -> http://federal-mogul.com/aftermarket...tm?Country=USA
2. Highlight "Catalogs" on the left.
3. Select "Make/Model Look-Up"
4. Select Your vehicle.
5. If you cant find your way from here, you dont need to be behind a computer.
Provided Via Federal Mogul's Website.
Stock Spring Specs
Part #.........Inside.........End..................End..........................Bar.............Install.........Load..........Spring........Free
....................Diameter...Type 1.............Type 2.....................Diameter...Height........In LBs........Rate...........Height
Front
5276...........4.090...........Square...........Tangential.............0.656.............10.50........1981.0.........303.0.........17.05
5596...........4.090...........Square...........Tangential.............0.671.............11.00........1440.0.........346.0.........15.19
5598...........4.090...........Square...........Tangential.............0.671.............11.00........1520.0.........346.5.........15.38
5600...........4.090...........Square...........Tangential.............0.671.............11.00........1600.0.........347.0.........15.63
5602...........4.090...........Square...........Tangential.............0.671.............11.00........1680.0.........347.0.........15.88
5604...........4.090...........Square...........Tangential.............0.671.............11.00........1760.0.........347.0.........16.00
5606...........4.080...........Square...........Tangential.............0.687.............11.00........1530.0.........421.0.........14.63
5608...........4.080...........Square...........Tangential.............0.687.............11.00........1640.0.........424.0.........14.88
5610...........4.080...........Square...........Tangential.............0.687.............11.00........1750.0.........424.0.........15.19
5642...........4.080...........Square...........Tangential.............0.687.............11.00........1860.0.........420.0.........15.20
5660...........4.080...........Square...........Tangential.............0.718.............10.75........1538.0.........598.0.........13.26
5662...........4.085...........Square...........Tangential.............0.750.............10.75........1690.0.........748.0.........13.01
5664...........4.085...........Square...........Tangential.............0.765.............10.75........1863.0.........707.0.........13.18
6486...........4.080...........Square...........Tangential.............0.671.............11.00........1935.0.........343.0.........16.63
Rear
5665...........4.300..........Pigtail..............Tangential.............0.485.............10.00..........580.0.........107.0..........15.42
CC635.......4.300..........Pigtail..............Tangential.............0.500.............10.25..........518.0.........104.0..........15.25
Old Nov 9, 2007 | 12:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Stock Replacement Spring Info
Sweet. Nice list. I needed this for a guy on Z28.com.
Old Nov 12, 2007 | 12:38 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
more data. tabled which camaros got which springs. havent made it to the pontiacs yet
Old Nov 16, 2007 | 06:20 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Heres a table of which springs trw/moog offer as stock replacements and their aplications. Now the table doesn't include every vehicle as the information wasn't provided via there website, and some of the data that was provided doesn't seem real accurate in a few cases.
Overall though most of the data seems to take sense, though none has been confirmed first hand. Once again this is all based off of the information I have collected from the federal mogul website.
Feel free to correct the table of any possible typos or new/unentered data.
To access the original source of the information follow these steps:
1. Click this link http://www.federalmogul.com/en/After...s/Catalogs.htm
2. Select make/model lookup
3. In the window that opens select your vehicles information.
4. Click "steering solutions"
5. Click "front springs"
File Type: zip
Old Nov 21, 2007 | 09:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I know that had to be a headache. I'm going to take a look at it when I'm not about to fall asleep.
Old Feb 6, 2008 | 09:27 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
New information. I'll try to compile a bit of a sticky when I return home.
https://www.thirdgen.org/firebird_spring_rate
https://www.thirdgen.org/camaro_spring_rate
Old May 27, 2020 | 01:30 PM
Tidan's Avatar
Does anyone happen to know what rate a spring tagged with "NNM" is?
Its my rear spring on my 85 T/A. Compressing it(outside the car) next to my new UMI rear spring(200lb) it feels a little stiffer - which is disappointing.
Old May 27, 2020 | 04:06 PM
Drew's Avatar
GM didn't disclose the rates, they just list them from high to low in the catalog. NNM is pretty common in FE2 cars. Anything from an early Z28 to a 92 Z28, or WS6 Firebird. NNL and NNN were the other two springs in the same range.
Old May 27, 2020 | 04:51 PM
Tidan's Avatar
Thanks Drew. My RPO's show mines a WS6. Currently redoing the entire suspension and really don't want to step down in spring rate. Wish GM published the rates.
Is there a way to correlate any of these part #'s with NNM?
Stock Spring Specs
Front
Rear
L6969
Jun 15, 2020 06:28 AM
pfsteichen
Jun 11, 2018 11:01 PM
5yearplan
Nov 12, 2007 12:36 PM
sully91rs
Oct 25, 2006 09:50 AM
onebluemcm
Oct 27, 2003 06:58 PM
