One side sits higher?
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I noticed one side of my car sits higher.
The passenger side sits half an inch higher than the drivers side.
Any ideas? Tweaked unibody?
Front springs are indexed right and they are Eibach sportlines.
I even tried swaping the rear springs from side to side incase the springs were sagged. (bought them used) Didnt make a difference.
hmm?
hmm?
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
what about the spring isolators? did ya remove them? mabe one is gone and the other is still there?
Front insulators were tapped on to make sure they didnt fall or move out of position.
I'm stumped. I never bothered to measure ride height with the stock springs.
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
I know this might sound obvious but are u sure the springs are seated all the way? sometimes they look like they might be but it might not be sat all the way on one side which would raise it on just that side
Car: 91 RS -- "SS"
Engine: 305 TBI
Transmission: WC T5
if you look on your control arm where the spring sits on it, there is a certain way the spring sets down inside of it...are you sure you got it ligned up right?
