Steering box has play, options?
Old Apr 17, 2006 | 07:32 PM
LottaBallsCamaro's Avatar
So my steering wheel has about 1" of play and I took a look at it last night and it is the steering box, anything I can do besides replace it? It's an 87 IROC-Z if it matters
Old Apr 17, 2006 | 07:56 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Pull it off and bench adjust it. There's a tech article on the montecarloss site that can walk you through. If it's leaking at all, pick up a rebuild kit (mostly seals, bearings and such). I wouldn't crack it open if it's dry though.
Old Apr 17, 2006 | 10:48 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I believe theres a way to adjust them without removing them as well. You disconnect the pitman arm connection and measure over-center torque at the steering wheel nut...and adjust the sector lash accordingly.
I know its vague but I cant seem to find the tech article I saw.
Old Apr 18, 2006 | 06:21 AM
naf's Avatar
naf
You could, possibly, do it with the box mounted, but you would have to disconnect the shaft, arm and hoses to get the box free of oil and by then you're only three bolts away from pulling it out. Pulling the locknut and loosening the adjuster plug could be a pain with it in the car as well.
Try this link:
The Monte Carlo Mailing List: Tech Articles
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
SlowAZ28
Aug 31, 2015 07:56 PM
zayne0
Aug 24, 2015 07:22 PM
