4th gen spacers+Drum brake spacer?
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
I'm gonna put 4th gen wheels on my 89 bird, and i'm gonna get 2" spacers. I have the slim spacers in the back because I have the steel drums instead of the aluminum. Should I put the 2" spacers on, then the slim spacer too? Never seen a post about the slim spacers in conjuction with the 2" spacer.
Try it and see.
Put the 2" one on first; then if the tires rub on the inside of the fender well at the bottom front of the opening, right behind the bottom corner of the door, then add the thin ones.
I doubt you'll need them though.
ambainb
Apr 25, 2016 09:21 PM
