Alignment?
Old Apr 20, 2006 | 12:44 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
Alignment?
I just finished installing front and rear sway bars along with the panhard bar, trailing arms,springs,struts and shocks. I drove the car for awhile and I noticed that it needs an alignment. Now my question is will I need an aligment after I install the front end rebuild kit as well? I got the front end kit from Spohn.
Old Apr 20, 2006 | 03:52 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
Yes, after changing the front end components you will need another alignment.
Old Apr 22, 2006 | 11:44 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
That all depends if you touched anything involving an alignment. Unless your touching the idler, pitman, or tierods the answer should be no. Hell even ball joints don't affect alignment we always sell once because 70 percent of the cars on the road are out anyways.
Old Apr 22, 2006 | 11:54 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
What else is left in a front end rebuild kit?
Please, enlighten me.
Old Apr 23, 2006 | 12:09 AM
Deimos140's Avatar
Car: 91
Depends
Is he talking about new sway bar links and control arm bushings. It all depends on what "kit" he speaks of.
Old Apr 23, 2006 | 12:18 AM
Lo-tec's Avatar
Re-read the post...come on now, it's only 4 or 5 posts......
Old Apr 23, 2006 | 07:50 AM
Deimos140's Avatar
Car: 91
My bad
It was late I was tired. My bad.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
