Car sits sideways after new suspension
Old Apr 22, 2006 | 12:41 PM
km7152's Avatar
Car: 1991 Camaro Rs
So i just finished putting in Eibach Pro's and Kyb Gr-2's all around, along with new balljoints and poly sway bar links up front. After a few days I start hearing a hollow noise followed by a rubbing in the rear. Tires are showing no signs, so no big deal except it pointed out the huge height difference in the rear. The driver side is easily 3-4 inches higher than the passenger, which seems abnormally low. Check the shocks/springs all seem to be seated fine etc. This common? Anything in particular I should check for, or possibly just try not to pay attention to? Maybe it just needs to break in, any suggestions would be nice.
Kevin
Old Apr 22, 2006 | 01:50 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
did you index the springs correctly?
Old Apr 22, 2006 | 02:07 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
did you happen to make the mistake of mounting your two fronts on one side and your two rears on the other? just checking possibilities..
Old Apr 22, 2006 | 02:12 PM
DuStangz's Avatar
Car: 79z28 91z28 89 irocz28
Engine: 383 350 tpi 350 carb
Transmission: th350 700r4 700r4
Axle/Gears: ford 8.8 3.73 ? 3.23
make sure you place the coil springs in the same direction ( where the coil stops) not very ease to explain sorry
Old Apr 24, 2006 | 09:28 PM
km7152's Avatar
Car: 1991 Camaro Rs
Ya i know the stupid things that couldve happen, and I checked. Both front springs are in the front, rear are in the rear. I have to check the indexing, i know exactly what you mean. At the time i was installing, i looked and assumed it didnt matter which way they went, but im sure theres logic behind it. I'm just seeing if its common or i ****ed up. Still hearing a weird squeaking noise in the rear going over bumps...i hate noises.
Thanks for the ideas, ill check the rest and get back on it
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
