18x10 rear wheel?
Old Apr 24, 2006 | 10:46 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Transmission: 5speed
18x10 rear wheel?
The rear rims I'm purchasing for my car are 18x10 in the rear with 6 degrees offset. Now to my knowledge I am ok to run 0 to 18 degree's offset on a 3rd gen vert.
Will a 18 x 10 with 6 degrees offset fit a 91 Vert lowered with hotchkis springs?
Thanks in advance
Old Apr 25, 2006 | 09:59 AM
CrazyHawaiian's Avatar
Car: too many ...
Offset is usually measured in millimeters (mm) either positive or negative. From my experience backspacing (measured in inches) is usually what people use to determine fitment relative to the width of the wheel. The offset can make a difference of course, but backspacing is usually more important. As long as you run the same backspacing as other guys on the forums with 10" wide wheels that fit good, and your tire choice gives you close to the same overall height, then it should fit.
Old Apr 25, 2006 | 07:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What's offset?
Old Apr 25, 2006 | 08:25 PM
TeK-91z28's Avatar
Car: 91 z28 convert
ah I meant millimeters, had a stressful day.
I guess I better find out the backspacing haha.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
