AIR BAG HOSE KIT
Old Apr 30, 2006 | 07:54 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
AIR BAG HOSE KIT
Does anyone know where I can get a replacement hose kit with all connections for my rear air bag inside the coil spring? Air bag is is Hotckins air bag that came with my rear drag coils.
Old May 1, 2006 | 07:23 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Go to Menards, Home Depot, Lowes, etc...and go into the plumbing section. There should be rolls of clear plastic line you can buy that will work, cant remember but think I either used 1/8"line or something like that when I replaced my lines. Just be sure it's the clear tubign that is soft and not the semi transparnet stuff that is hard. You get like 20-25' for $2 or $3.
Old May 1, 2006 | 06:53 PM
mcbchild's Avatar
What about the connections for holding the hose onto the air bag and the connections at the end of the line to inflate the bag?
Old May 1, 2006 | 07:35 PM
IHI's Avatar
IHI
The ends on the bag parts are all barbed, so pending psi under 50 lbs they should self lock themselves into place. Any more pressure than that and it'll shoot the line off the bag or schrader valve.
They may have some small clamps in that area also just for these tiney things.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
wild1
Aug 27, 2015 09:01 AM
BurlyChev
Aug 22, 2015 01:52 PM
