End Link torque specs
Old May 3, 2006 | 11:37 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I noticed how the specs call for 16 ft-lbs...But unfortunately I did not have my torque wrench with me last night when i was putting my new sway bar on the rear.
Is it that critical? I just tightened them down good and made sure they were pretty even on both sides.
Old May 4, 2006 | 06:25 AM
There's not really a torque spec.
They should be tightened until the bushing deforms to the same OD as the washers; no tighter.
Old May 4, 2006 | 07:25 AM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
I got the 1LE end links from TDS, so the washers are inside the bushings.
Old May 4, 2006 | 08:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The threds on the bolt are only 1-2inches long (if you have GM nuts and bolts) the nut will bottom out on the bolt.. just tighten till the nut stops
1992rs/ss
Jan 31, 2025 05:10 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
