Iroc or WS6 steering box in 82 z?
Old May 6, 2006 | 06:14 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Well, I replaced my rag joint and now the steering box is leaking from the part where the rag joint spline meets the steering box. It's the original steering box, and I found an IROC box but it's a later, 87, box.
Can I put this in without any issues? Will all the fittings work in the later steering box? I have bought stock, 1982, hoses and all, any suggestions on this set up?
Old May 25, 2006 | 10:12 PM
LT1guy's Avatar
Car: 1987 Trans Am
Not sure if the spline count is the same, but worst case you could use the whole shaft from the later box. The hoses shoukld work fine with the later box, GM changed to o-ring style hoses (from flare) around '78. The box will bolt up just the same, and the pitman arm is the same.
Old May 25, 2006 | 11:44 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
If you don't use it, I'd be very interested in it
Old May 27, 2006 | 03:28 AM
83 Crossfire TA's Avatar
The Iroc box should have the same steering ratio, just thicker stops so you’ll get a wider turning radius (or your front tires will stop rubbing if they’re rubbing now), otherwise you’ll be fine
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
