Anyone have this problem with their steering wheel?
Old May 7, 2006 | 03:44 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
It's wierd because i just did an engine swap and it messed up a day after. Im able to pivot my steering wheel 360 degrees around the tilt part. Has this happened to anyone before?
kent
Old May 8, 2006 | 09:43 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
Do you mean you can twist the column at the tilt? if so there are 4 torqs head bolts down at the bottom of the top part of the column that always come loose and cause "play" in the column. If you had play in the column and now it seems to be almost hanging off don't twist it anymore.. it needs to be taken apart and those 4 bolts need to be put back in with locktite on them, by the way this is not a job for the light hearted.. its a real pain in the ***.
Old May 10, 2006 | 07:11 AM
k's89rs's Avatar
ok so i just need to tighten those bolts? thats what ive been told.
thanks
kent
Old May 10, 2006 | 07:57 AM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
you should remove each bolt and put locktite on them before putting them back in and tightening , only do one at a time, you will need a tool to remove the lock ring just under the plastic cover beneath the steering wheel, it's actually a big pain in the *** as you'll find out. Just take your time and be patient
Old May 11, 2006 | 10:04 PM
k's89rs's Avatar
would that be a tool i could get from the autopart store? i know i have to have a steering wheel puller...
Old May 13, 2006 | 02:02 AM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Yes, a decent auto parts store should carry the tool or be able to direct you to a shop that has it but I would recommend you go to a shop like a pep boys or similar shop because some parts guys may not know what you're asking about, it is a fairly simple tool, screws onto the primary shaft, has a u shaped piece that presses down on the large plate under the plastic cover just under the steering wheel so you can remove the clip that holds the whole assembly on. If I don't make sense I can shoot photo's of tool this weekend and that may make more sense.
Good luck
Old May 13, 2006 | 03:20 PM
k's89rs's Avatar
ahhh. that makes sense. im going to probably do it next week sometime. thanks for your help!
Old May 13, 2006 | 10:55 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
anytime
Old May 14, 2006 | 09:43 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My 86 IROC had "special" bolts in the column. I had to buy a set of sockets (got them at Sears). The bolt heads look like torx bits. I did mine a couple of years ago and they are still tight.
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
