Getting fustrated!!
Old May 16, 2006 | 01:06 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Getting fustrated!!
Alright, ive been trying to chase down a vibration hopefully i can describe it right. Its like i'm driving on a road that has been patched up and has minor pot holes in it, its not very rough but its enough to feel it. i feel it more when im going down a smooth road then a rough one. It started happening after i took the car through quite a lot of curves heading to the coast, (i was doing lots of breaking/speeding up, the ROTOR's are not warped ive checked them)
I did take the driveshaft off the car and took a look at the u-joints, neither of them looked/felt as if they were bad. the front yoke felt a little loose, but i attruibed that to it being a 23 year old car. Took the car to get the tires reballanced, but that wasnt it.
The tranny mount was broke, i fixed that, but the vibration is still there, i can feel it through out all speeds, low speeds being the worst, high speeds i can barely feel it, I can also feel it when i'm breaking (which led me to check the rotors, which were still good)
Anybody have any ideas on what else i should check?
Old May 16, 2006 | 01:22 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
id check the ball joints or tie rod ends.
Old May 16, 2006 | 01:50 PM
RGZWS6's Avatar
I'd check the front wheel bearings or better yet, just replace them! Soopa cheap and easy.
I actually fried a set on my driver's side one night on the expressway from an extended time at 110. Slowed down, then all of a sudden, I had a vibration/grinding noise coming from the front wheel. They were in such bad shape, it took a set of pullers to get the rotor off.
Old May 18, 2006 | 12:40 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
While going throught the turns, did you lock up any of the wheels? You many have flat spotted one or more tires.
Old May 18, 2006 | 02:56 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
no wheels were locked up during the curves , gonna check out the wheel bearings sunday (dont have any free time until then) And let you all know.
Old May 19, 2006 | 07:45 AM
camarolizard's Avatar
Car: 84 sport coupe
Engine: 2.8,for now
Axle/Gears: junk
sounds like a busted belt in one of the tires
Hawkeye1980
Jul 10, 2014 12:21 PM
NY87Iroc
Aug 22, 2012 06:34 PM
MrBeefy334
Jan 24, 2010 03:37 PM
Firebreed
Dec 30, 2005 10:33 PM
