.... Getting fustrated....
Old Dec 13, 2005 | 12:49 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Alright, Every once in a GREAT while, my SES light will come on during a ride... Theres no connection between weather/driving style/conditions other then it's been cold out side . Anyways, ive hooked up to a code reader (two of them) No codes came up... Ive even shorted the two pin's to make the ses flash.. all it flashes is 12... any idea's on what the heck is going on here? thanks for the help guys. the engine is a 2.8l Carbed Stock cc-Verajet (cali car if that helps at all)
Firebreed
"Fustrated to the max"
Old Dec 13, 2005 | 10:32 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Could just be going temporarily lean or rich, tho AFAIK, the code should stay in the system?
Old Dec 13, 2005 | 11:07 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
yea thats what is bugging me.. If the computer isnt storeing any codes.. what other things is that computer doing?
Old Dec 13, 2005 | 12:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought they stayed in the system untill power was cut?
Highly strange? Do you have another ecm, or can you get another ecm and see if that fixes it?
Old Dec 13, 2005 | 01:26 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Not at the moment, i might beable to get a J-yard computer.. but with j-yard pieces you have no clue what your getting... is there any checks to do with the comp to see if it is working correctly?
Old Dec 25, 2005 | 01:38 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Just an update to for you all, The SES light is coming on more frequantly now, i havent had a chance to put the car up on a scanner or short out the pins yet, looking to put another scanner on it sometime this comming week, any other ideas on what i can do to check it out? Ive also noticed lately that the car is running rougher, Going to to do a tune up (cap, rotor, wires) and maybe replace the coil (im sure its the stock coil) soon, any other idea's on what i should check? btw the scanners all say that the O2 is reading lean.... However i have yet to find any vacume leaks on the car.....
Old Dec 25, 2005 | 03:46 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
my SES would come on frequently when driving......turned out to be the EGR vacuum solenoid
Old Dec 28, 2005 | 10:24 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Have you checked for the code soon after the light came on?
I have a couple of thoughts here:
1: The computer dumps the information after 40 warm up cycles. If it's been 20 days since the light was on, the code's long gone. (Drive it to work every day for 20 days, warms up twice a day...just for the people that would think that I'm crazy)
2: The computer might not have a full time hot like it should, causing it to lose memory after you turn the key off. Check the hot lead to the ECM from the battery.
Old Dec 29, 2005 | 01:12 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
if its not raining tomarow, ill check the codes as soon as it comes on, and ill also check the wireing to the ECM, and let you all know. thanks everybody for the help
Old Dec 29, 2005 | 06:09 AM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
i don't know whether this is bs or not, but a long time ago, i heard that the ses light has to be on for 2 minutes to set a code in the computer. i don't even know where i got that, but it may be worth considering...
Old Dec 29, 2005 | 08:03 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
That's not true, if the light comes on, it sets a code.
Old Dec 29, 2005 | 08:43 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
as soon as the ECM sees a problem thats code worthy, it sets the light, there is no time delay or anything for it. otherwise there would be tons of things that would never trip the light, like intermittent misfires, or EGR problems and all that.
Old Dec 29, 2005 | 11:17 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
have you tried jumping the pins and driving it? I do recall reading something about the light flashing (or not) for certain info. What exactly I cant remember tho I am sure someone else can enlighten the crowd about the open/closed loop thing.
Old Dec 30, 2005 | 10:33 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
When you ground the ALDL with the engine running it shows Open/Closed Loop status. If the light is flashing very quickly, it's in open loop. If the light is blinking an on/off cycle about once per second, it's closed loop.
When it's in closed loop(slower flashing) you can see whether it's rich or lean depending on if the light is on longer than it's off and vice versa. If it's on longer, it's rich, if it's off longer, it's lean.
Manual trans missions can really see this when you decel with the clutch engaged. The light will stay off as long as you are engine braking because the computer has literally shut off the injectors for the moment so it doesn't waste fuel when you don't need it.
ULTM8Z
Sep 16, 2015 09:15 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Roshambo
Aug 24, 2001 08:48 PM
CrazyHawaiian
Car Audio
Aug 6, 2001 04:16 PM
IROC315
May 15, 2001 10:34 AM
