sub frame connectors
Old May 16, 2006 | 02:48 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Well some of u know i have an 84'bird, ive been hearing that sfc's should be 1 of the first investments. r these really nessecary? im not doing any racing with the car. will these improve the steering and suspension? plz let me know ur opinion on these sfc's.
Old May 16, 2006 | 03:10 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
OMG trigger how many new treads are you gonna do you ask alot of questions
Old May 16, 2006 | 03:15 PM
Car: 84' Trans Am
i need to know if there neccesery becuz it might be my next investment.
Old May 16, 2006 | 03:20 PM
kjvail1204's Avatar
Well if you plan on putting any power in it at all you shoudl do it, the fact that the frame is not one peice makes alot of things go wrong. I have a friend you flexed his car so much (4th gen TA) he cracked his windshield. You will stay better in corners as well. Your car wont roll as much.
Old May 17, 2006 | 11:07 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I recently had Spohn SFCs installed on my 84 bird, and noticed an immediate difference. The creaking when going over a really lousy bumpy road was significantly reduced. Before I would feel like the car was flexing with the road and now it's just the suspension that travels. I still hear some creaking and flexing up front from the front frame rails at times, so I plan to do a 3 point strut tower brace in the future.
Old May 17, 2006 | 11:30 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i say even a stock car needs them. these cars are like wet noodles without them. you'll notice an immediate improvement in all types of handling, the creaks will go away, and dash rattle should be minimized, if not completely gone.
Old May 17, 2006 | 11:32 AM
Shagwell's Avatar
Car: projects.......
hit the key. You'll find more info that way than anyone will post. Always search first, then post if your question is still un-answered.
- YES! I've seen V6 cars that cracked the b-pillar due to chassis flex. They're not a mod, they're a necessity.
Old May 17, 2006 | 06:33 PM
Car: 84' Trans Am
thanx 4 the help guys, i think im going to invest into getting the sfc.
Old May 17, 2006 | 07:38 PM
Car: 84' Trans Am
i have 1 more ?, since i dont have acess to a welder, could i just get away with bolting the sfc on instead of welding it?
Old May 17, 2006 | 07:48 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
No, find a local shop that will weld them in for you. Most muffler places will do it. Expect to pay $75-150. You may want to pull your sills out and roll the carpet back from the doors before you have it done though-or remind the shop to. The heat from welding can burn the carpet.
I agree with MW, even a stock car needs them.
Old May 17, 2006 | 07:50 PM
Car: 84' Trans Am
thanx.
Old May 20, 2006 | 08:08 AM
L.I.N.Y.92CAMARO's Avatar
Do the bolt ons really flex that much more then the weld in ones?
Thanks,
Old May 20, 2006 | 08:42 AM
mw66nova's Avatar
Engine: 7.0L
yes. my 350 that i'm taking out due to a cracked waterjacket makes about 450ftlbs. the flex from not having mine welded in was making the hatch rub against the rear quarter. it rubbed so badly that the paint is flaking off. welding them in was the best thing i ever did.
Old May 21, 2006 | 11:33 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
if you buy bolt in ones have them welded to thats what i did with mine
Old May 21, 2006 | 12:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Why spend the extra money for bolt in ones if you are planning on welding them. Just get the weld on ones and weld them on.
Old May 21, 2006 | 07:47 PM
Car: 84' Trans Am
would the car flex if i bolt them in, its only a 2.8 and i wont be drag racing it?
Old May 21, 2006 | 08:15 PM
mw66nova's Avatar
Engine: 7.0L
with a 2.8, you'd be fine with them bolted in. but if you ever decide to put some more power to the chassis, you may want to think about having them welded in.
Old May 21, 2006 | 08:17 PM
Car: 84' Trans Am
cool, becuz i really dont want to pull up the carpet but i want to get the sfc to stiffen up the frame. thanx 4 all the help guys.
Old May 21, 2006 | 08:29 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I don't think that's very sound advice. The engine isn't the only thing that acts upon the chassis when driving. Sharp turns, emergency braking, and other manuvers like that can stress the chassis just like the torque from an engine. Eventually the bolts holes will elongate and render the SFCs useless. It may take a bit longer since the power isn't there, but it will eventually happen.
I would go with welded SFCs and never worry about it again.
Old May 21, 2006 | 08:33 PM
Car: 84' Trans Am
yeah it would prob. be better to have it welded in. ill keep it in mind.
Old May 21, 2006 | 08:41 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Old May 21, 2006 | 08:42 PM
mw66nova's Avatar
Engine: 7.0L
you'll have to pull up the carpet to bolt in the bolt-ins cause the bolts go through the floor.
i ran the bolt-in's for 3 years before i started having problems. they had been on 3 cars before i finally welded them in to the current car. only reason was cause i started twisting the car when i finally got more power to the ground. but again, my car is built for straightline performance, and the car is not put through emergency braking and fast, hard cornering.
i suppose if that is the kinda stuff you do with the car, then yes, weld-in's only
Old May 21, 2006 | 08:45 PM
Car: 84' Trans Am
well then ill probaly have them welded in. if u have to pull up the carpet either way, might as go with the weld ons. gives me an excuse to rustproof the floor.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
RS Reaper
Sep 27, 2015 07:04 PM
