Just installed Comp engineering universal swaybar - pic inside.
Old Jun 14, 2006 | 12:23 AM
87_TA's Avatar
Just installed comps universal swaybar, figured it was better than spending $450+ for a BMR,Spohn ect..
This one is $260, need to figure out how to mount it, I mounted mine backward - they want bar attached to chassis and links to axle tube..
I weld brackets to shock mounts ( better than risking tube distortion)
and links to unibody framework.. Was rather straight forward, alot of hours trial fitting and grinding, cutting, welding...
Here is a pic, Camera went dead after this shot, if anymore needed I can get..
Old Jun 14, 2006 | 12:12 PM
Shagwell's Avatar
Car: projects.......
ahhhh, decided to "mule" that thing yourself, huh? Looks good.
- You're not the first to mount it that way on our cars - I've seen a pic of another one done that way. Doesn't matter which way it's mounted, still does the same thing. - Been to the track with it yet?
Old Jun 14, 2006 | 01:06 PM
87_TA's Avatar
No,
Weather permiting this Friday and/or Saturday.
Should make a good difference in 60ft I hope... Being that Right rear
bumper was almost touching ground before on launch.
Old Jun 15, 2006 | 12:23 PM
Shagwell's Avatar
That's the one thing I've been working out with the new chassis for my car, which is basically gonna be a mule suspension for my 10.5 outlaw car. With ladder bars or 4-link you pre-load to make it track straight and to squash body roll. If your set-up tracks straight, you go to an anti-roll to keep it square. I'm going to try a sliding tq arm set-up in mid-high 4sec(1/8) 10.5 outlaw car.
- The anti-roll is gonna have it's work cut out for it......
- I'm ancy to hear how it does....
Old Jun 15, 2006 | 06:22 PM
BlownBird's Avatar
I have mine setup the same way, it is a Wolfe Racecraft piece. Consistant low 1.30's with mine on radials (a best of 1.310).
87_ta, what did your 60' look like before install?
DonB
Old Jun 16, 2006 | 12:06 PM
Shagwell's Avatar
BlownBird - your's is one I was thinking of.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
